Connecting NODE to external DAC
6 Kommentare
    Hi David
    Your COAX connection is correct but log out of Qobuz and then log back in using 24/192 in the streaming options. Details can be found here; https://support.bluos.net/hc/en-us/articles/360000264028-How-do-I-ensure-Qobuz-is-playing-CD-Quality-on-BluOS
  • Antonio Brandao
    Hallo
    Can I use an optical cable to connect to the DAC/Amp to  node n130?
    Does it work the same? Does it maintain the audio quality? thank you
  • Permanently deleted user
    You can use the analogue, coaxial or optical outputs. If you use the analogue then you are using the DAC inside the NODE, if using the coaxial or optical output then you are using the DAC inside the DAC / Amp. Use your ears and decide what connection sounds best to you.
  • Antonio Brandao
    Thanks for the answer,
    But which one is the best, coaxial or optical? or is it the same? I have an optical cable, but if coaxial is better I will buy a cable.
    thank you
    In theory no difference on the digital outputs, your DAC may however might be different.
  • Antonio Brandao
    HI'll try it, my dac/amp is coming, SMSL DO400, I hope I made a good purchase. (Headphones HD 800s)
