Bluesound Node 2i repeatedly turns off within 15 seconds after robot
    Permanently deleted user
    In the BluOS App please select Settings, Send Support Request, so the Bluesound Support Crew can review the log file and take a closer look.
    If you cannot do this because you only have the one device then use email support@bluesound.com
  • Permanently deleted user
    Power off the NODE and reboot your Router, keep the NODE without power for ten minutes. Now power it up and try again, if this fail temporarily connect an Ethernet lead directly from the NODE to your router (moving it if necessary) and see if the LED at the front will turn to solid Blue.
  • Richard Sloves
    I followed your instructions, the Node was already disconnected for 30 minutes so I rebooted the router, powered up the Node but the problem still persists. Direct connection via ethernet to router failed to resolve the problem.
