Powernode 2 red light blinking
2 Personen folgen
It is not stuck in any firmware update and does not need to get cooled down nor reseted so please no standard technical answers. It is obviously an intrinsec issue such as swollen capacitors on PSU or amp stage malfunction. Can you point me on how to open up this gizmo cause unscrewing the 2 screws from the back, wont do nothing. Thanks
Hi Master Blaster
Your POWERNODE is in Protect Mode to avoid blowing your speakers. If leaving it disconnected from power for 24 hours and retrimming the speaker cables does not resolve the issue, the PWERNODE has a failed Amp board and will require service.
A full listing of LED Blink Codes is available by clicking here.
