Default Bluesound for Node 2i
BeantwortetHi i set an alarm to play a playlist normally it works fine.
The playlist is on my pc and connects via a Network cable.
It lost connectivity and started playing the annoying default alrm sound... how can i turn this off.
I normally remote into the pc but it lost connection
This is why your Bluesound Player played the fallback alert noise. We did not want you to be late for work.
thanks so how do i turn it off....if im streaming something and it looses connectivity...it will play the default sound...surely there is an option to turn off this...i schedule music...it works normally well...but in this case...at least there should be something better than that horrible sound....
You cannot turn this off as the feature is designed to mimic a clock radio yet still works if the audio is interupted. It is not designed to schedule music. To stop the alarm you can select play/pause to defeat the alarm or select a new audio source or restart manually the desired preset.
