    Permanently deleted user
    The alarm switches to the default alarm if the radio stream is unreliable, I asked if it’s a morning alarm as many people on different platforms stream at all roughly the same time and this can lead to drop outs. One of my favourite stations fails with a 7am alarm but works fine at 6.58am
    You could try another radio station, or save the station in the TuneIn section with a lower bitrate (you can choose streams on many stations but not all)
    If you can recreate it successfully then do log a support ticket immediately after the alarm switches to to the default sound, this will send the logs for further checking.
  • Permanently deleted user
    Hi James, what is the music source of the alarm that’s failing and is it a morning alarm?
  • James Devaney
    Yes but it shouldn’t matter when alarm is scheduled…it shouldn’t stop playing the radio station or music then start playig inbuilt alarm sound…I think I might have solved it….you have to setup alarm in one take if you make a mistake you need to delete it and recreate …think it’s a bug
