Node static like pooping noise, and thug noise when changing track.
    Permanently deleted user
    I am just another user here on the community forum, some DACs unfortunately do make a noise when changing bitrate but not all and this is an issue talked about on many hifi forums as the issue shows up on other hardware platforms.
    You said ...
    "However I can not listen to it's internal DAC at all."
    What is the problem exactly?
