BluOS Controller 4.6.2 loosing connection despite no WIFI interuption
    Alain DW
    Lossless
    Probably a local network issue.
    Try making DHCP reservations in your router for every Bluesound & controller device in your network.
    Reboot your router to take effect.
  • Jan
    Thanks for the tip Alain.
    I have had the same reserved IP# for the PowerNode since 1996 though and never experiencing these hickups earlier.
    Jan
  • Alain DW
    Lossless
    Did you also make a reservation for your controller? (iphone/ ipad etc.)
