Bluesound Playing Default Sound if it loses WIFI connectivity
BeantwortetPlease advice how to turn off Bluesound Playing Default Sound if it loses connectivity to playlist.
ok i have a playlist on a usb it is scheduled to play as an alarm.....for example to play at 8AM saturday.... it plays for 10 seconds or so then stops and plays some in built default sound that bluesound has...if i play normally its fine..this is a Node 2i
the thing is this alarm is a nuisance feature.. should be an option to just disable it..
