VRMS Specs on BlueSound Node Icon
BeantwortetLooking around for the specs on both RCA and XLR output specs for the Node Icon. It doesn’t seem to be advertised/published anywhere.
Could anyone help confirm please?
Hi Matthew
In speaking with our Quality Assurance Team the NODE ICON is rated at 2V for RCA out and 4V for XLR.
The XLR and RCA output on my Node Icon is the same, and very low as also mentioned by other (even the built-in RIAA has higher output). Is it a bug, XLR normally has 6db more gain?
My amp is a Marantz PM10 and accepts 4v input for XLR and 2v for RCA, so if the Node Icon outputs what you say then there should be a difference in volume level when listening.
Br
Rasmus0
