Need a manual for the original vault
Beantwortetcan I get a link to the manual for the original bluesound vault. When you hit the link on the website for the blue sound vault manual it takes you to the manual for the vault 2.
Specifically, I need to know if this is true for the original Vault or only the Vault 2: "The analog RCA output on Bluesound's NODE and VAULT models includes a built-in DAC that supports a minimum of 24-bit/192 kHz*, so there's no need for an additional DAC for output."
If so, I should be able to stream Tidal at 24-bit/192 kHz* using my original Vault without a separate DAC? is this correct?
Thanks for your help, David
0 Kommentare
