Bluesound needs power on off
    Permanently deleted user
    Settings…diagnostics…Reboot
  • Janne Johansson
    I was coming here to say the same thing. My Node ICON loses eARC connection to my Samsung TV and the ony thing that helps is rebooting the ICON. And I get it that one could say that it's the TVs fault, but it worked flawlessly with n130 and n132 so for that reason I'm thinking it might be the ICON.
    What I'm after is the ability to reboot nodes using the remote app. Can be in the depths of the menus, maybe under player. Having it would not hurt anyone and having it would help when the software on the player craps out and requires a reboot. Also if possible a long press (3s? 5s? 10s?) of the power button on the remote could do the same?
    So what I'm after is not exactly power off but reboot I guess.
  • Janne Johansson
    Turns out there is a reboot option under dignostics. Gonna give that one a try next time.
