Tidal interface diferences
    You can try logging out and logging back in but it is likely caused at the TIDAL need by how they are tagging albums and this differing from their internal process from the API provided to third party Apps like BluOS. I do know that the most recent BluOS release included a slight refresh to some API libraries so may improve over time.
