LG tv to power node via optical
4 Kommentare
  • Brian
    Lossless
    Also look at the sound out format. PCM may be your best option. I have an LG OLED but am using HDMI eARC out.
  • Pete
    Thanks both. I have selected optical out in the settings sound menu and the sound format is set to PCM. Can I connect via hdmi eARC? Is there an input on the node 2 for this ?
    Thanks again for your help
  • Brian
    Lossless
    No HDMI on Node 2.
    Possible bad optical cable?
  • Pete
    Bit of an update.
    I ran the cable from my cd player to the node.
    Worked fine.
    So the issue is either a setting on the tv that I'm missing ( don't think it's this as I have followed the instructions to the letter),  a faulty output on the telly ( unlikely I feel, as the lg tv has good build quality) or some sort of compatibility issue. If it is compatibility, then it could come from node or tv I guess.
    I am truly flummoxed. I have put a ticket in with Bluesound. They have just come back with articles at the moment.
    Any ideas would be gratefully appreciated.
