No audio on Airplay 2 - Node 2i
BeantwortetI moved my Node 2i into a different room and changed its name. Now I can't get any audio via Airplay.
- it was working fine with Airplay 2 until I changed its name, even in the new room
- The volume on Airplay on my iPhone shows as 0, and I cannot adjust it with the touch slider or volume buttons
- My mute switch on the phone is not on
- Airplay worked until I changed the name of the Node. Changing it back does not fix the problem
- I have tried rebooting the Node2i and reinstalling the network settings to no avail
- The Node 2i is not muted: it works fine with Bluetooth, streaming services and via the Aux in cable
- I also have a Node X, and Airplay works fine with that using the same phone. I can alter the volume on the phone's Airplay as usual when connected to the Node X
Any idea what's wrong and if there's a fix. I can't remove the device and reinstall from my phone as it 'just finds it' in the list of possible Airplay devices
Thanks, it's not in Apple Home (I don't use it but reinstalled it on my phone to check). No difference rebooting router either :(
