Buying my first sub
BeantwortetI have a powernode and am thinking of buying my first sub (more for music than films). I know nothing about subs or their connections. I see there is a single sub out socket on the powernode. I'm not very clear what sort of connection I'm looking for on a compatible sub. At the moment I'm considering a SVS SB-1000, but am not totally committed to it yet and not do I understand what socket on the sub I'd connect it to - is it LFE (whatever that is). Also, am I supposed to keep my main speakers attached to the powernode or do they then go into the sub, which has black and red speaker connectors? Thanks in advance.
Hi John,
If you decide to go with the Bluesound SUB+ option, you'll be able to easily connect it to your POWERNODE either wired or wirelessly via BluOS.
For additional details about the SVS SB-1000, you can check out this helpful community thread - Community Thread
If you need personalized assistance, please don't hesitate to contact our support crew by sending a support request to support@bluesound.com. One of our friendly support team members will be more than happy to assist you.
Thanks for #LivingHiFi
Brilliant. Thanks. I didn't realise the Bluesound sub - I thought you needed the soundbar for that. I'll have a look at it. Thanks
