No sound from speakers with Airplay but headphone output works fine.
BeantwortetI have just purchased a NAD C3050 with BluOS module. After initial setup to C3050 to the network I can select it for airplay from my iphone. But there is no sound from my speakers.
Here are some observations:
1. When using airplay from iphone, althought the speaker sound is mute, the headphone out put is find and I can listen to music with my headphones. That proves that airplay works.
2. I can select to use "line in" input and it works fine. That indicates the speaker connections are fine?
3. While the speakers make no sound when I do airplay I see the two uv meters moving as expected. They also responds to volum control knob.
Could anyone tell me what I might have missed? Any suggestions?
Hi JingFeng,
Please be advised that the C3050 will not output audio to the speakers when there is a headphone connected. Are your headphones still connected to the NAD C3050? Is the issue you are experiencing only with Airplay or you don't hear audio output at all?
Please reach out to our support crew using by sending us a support request using the BluOS app.
Thanks for #LivingHiFi
