Blu0S couldn’t load content
Beantwortet-
This is often caused by your App not discovering the Player due to your home network blocking traffic. I have escalated this to our Support Crew so they may take a closer look. They will be in touch via e-mail to ask some specific router details off you and provide more 1:1 troubleshooting.
I also have the same problem. Unable to load any bluos app screen. My psp alpha iq speakers can play the last music I played thru bluos. Nothing else because the app hang.
after the install off the new update i have a problem with the mine phone where I have installt tthe update.
Mine android phone tells me she can not find the players and when he sees the players there is no sound
Thanks for you support I have discoverd that one digital coax cable was not realy good connected to the Node.
now every works perfect thank you verry much
greets Toon
Gisteren functioneerde app goed en vond snel de spelers.
Vandaag wilde ik muziek streamen maar de spelers zijn weer niet zichtbaar! Vandaag heb ik de node opnieuw gereset door de stroom er af te halen. Helaas zijn de spelers weer niet zichtbaar in de app
Serie number van de node K59N2B06735
Yesterday the app functioned well and quickly found the players. Today I wanted to stream music but the players are not visible again! Today I reset the node again by removing the power. Unfortunately, the players are not visible in the app again Serial number of the node K59N2B06735
Hi Theunissen
Please continue to work with our Support Crew and the Open Request you have with them to help you out...
Hi Tony currently the node is connected with a cable to my home network. can I also connect the node with wifi? if so I would like to receive a manual that I can use to connect the node with wifi to the router
My NodeNano is now frozen. On the app it says”Couldn’t Load content”. I can’t stream usic or play fro an external HD. At this stage, the NodeNano is a useless piece of junk.
HI Terry
Please reach out to our Support Crew at support@blueosund.com. They will be happy to help troubleshoot your network connection.
9 Kommentare
