Combining inputs from powernode and Flex
    HI Dimitri
    Your diagnosis is bang on. You will have to break the group and recreate it swapping out one Primary for the other...
    -OR-
    If you haven't bought that Phone Pre-amp yet, may I suggest the Bluesound HUB. Among it's many uses, it is a moving magnet phono pre-amp and will allow you to select the turntable as a source without having to break and recreate the group.
  • Dimitri Souffree
    thx for the fast reaction.
    I did consider the hub but then I would not have the extra speaker or have to buy the hub and a flex which is in my opinion quite expensive just to have an extra speaker and input.
    Do I understand well that the 2 groups cannot exist next to eachother or would I just have to select the other group when wanting to change the primary? That would be an acceptable solution to me.
