CONNECTION PROBLEM BLUESOUND NODE 130, DDC SINGXER SU2 AND DAC DENAFRIPS PONTUS
    Mark T.
    Sr. Support Crew Member
    Hi Dermailly,
    Please connect the Bluesound NODE directly to the Denafrips DAC and see if that fixes your issue.
    If you need more assistance with this, please reach out to our support team via email to support@bluesound.com
    Thaks for #LivingHiFi
  • Tom Pil
    Hallo, same Problem here and i wont connect directly...Your answer is not an answer...the USB Sounds much better then coax/toslink...so do you have a helpful answer (an no i wont connect directly;)) thx
  • Permanently deleted user
    Tom, the NODE is designed to connect to a DAC not a DDC, if you need further clarity follow the instructions in the Official Comment.
