System expansion: 2nd node, power node or powered speakers
BeantwortetI currently have a Node X with old Yamaha receiver and Polk speakers in my workout room. Using a Mini 2i in the kitchen. I'm deciding on the best way to manage the expansion to my living room. This is not my primary listening system. This system is used for having music throughout the house. I'm deciding whether to get another Node to use with amy 2018 Denon amp and wired Dali Menuet speakers, get a power node to use with the Menuets or buy powered Dali Oberon or PSB speakers. Sound quality is the key consideration while keeping it simple and minimizing cables. Thank you for any guidance.
If you are happy with your current Living Room sound system, simply buy a NODE to unlock it for BluOS. This is your fastest, easiest and most economical solution.
