Help me with gain issue from hub
I have a Bluesound hub and a node2, I have bought a record player and connected it in the phono input of the hub, node2 has full volume, when selecting phono in the app, the volume is approx 20-25 dB lower than when streaming qobuz, can I fix this, would a riaa with adjustable gain solve the issue or would the bluos system just lower the gain, node 2 is connected to Lyngdorf 2x400w 4ohm system via coaxial but I am simply not able to listen to loud music from a record
0 Kommentare
