"Grouped Player Connection Failed" behavior
    Sounds like a general network lag issue on the secondary streamer. Check out www.bluesound.com/network101 for great tips or select Send Support Request in the BluOS App and our Support Crew can help troubleshoot and make recommendations on how to prevent this from happening in the first place.
  • Robert Carroll
    Thanks. can't get the network101 link to come up but the two Nodes are connected to the same gigabit switch and ping round trip to each from my laptop is 1ms, consistently, with zero packet loss. In any event: the main purpose of my post was to suggest that the behavior of the Nodes be changed so in the event that one can't reach the other, the default player should continue to play. In my case at least, that would prevent my getting trouble tickets from the spouse. :) Thanks!!
    Sorry about the typo Robert - link corrected...
