Static sound from speakers on two new Powernode Edge
  • Bill Cherryholmes
    Thank you Seppi.
    But reversing had no affect. Makes sense because it is not polarized. And there is nothing plugged into it. It is strictly for streaming only.
    Can't take it to a neighbor. And I can't take it to the dealer because I bought it online.
    Thank you though,
    Bill
  • Kent Jensen
    Hi Bill, I don't know if you've already got an answer elsewhere, but I'm in part writing this reply for others with the same problem to read.
    I too encountered this yesterday when moving my Edge from one speaker system to another. It had been working as it should where it was connected up until yesterday. With the new speakers, I had a loud and constant noise from both speakers. I would describe it as white noise. At first I thought the Edge was broken, but after measuring the new speakers I knew what was the problem. They had a highly capacitive and complex impedance which the Edge didn't play well with.
    You might say that it can't handle complex speaker loads is a design flaw in the Blusound Edge, but my speakers presented a difficult load I'll admit - alltough all the other amplifiers I have used them with worked fine. My speakers are DIY built, and I had to change the crossover somewhat - that solved the problem for me. I read your speakers are the Polk XT20. Erin measured them over at Erins Audio Corner . Their impedance curve seems pretty standard to me, but it might be that they present a capacitive load above the audio band (that does not show up in the measured curve). I think you have to simply accept that the Edge won't work properly with the Polk XT20 and use a different pair of speakers (or swap the Edge out for another streaming amplifier solution).
    Best luck to you!
    Kent
