Can't find 'audio settings' in menu
BeantwortetEine Person folgt
I want to use USB out on my node 2 But it doesn't work. And I can't find 'audio settings' in menu.
What to do?
Done.
Dac displays: dsd 11,2mhz But no sound0 -
It wasn't a dsd file. Deezer 16/44,1
Radio paradise alsof shows dsd 11,2mhz
Bluesound does not support dsd. But node 2 is source with USB out. Where Comes dsd from?
I used same USB-in on the mdac+ with laptop and that works perfectly.0 -
Yes it is usb-B for laptop/computer. There is usb-A for Mac/Apple.
Is it spdif on USB om the node? For as i know is every dac with usb-in for use with computer.0 -
Thanks for the replys btw
Yes node 2, like i said in openings post🙂
Then i misunderstood about the possibilitys.
Thanks anyway.0
5 Kommentare
