Node X to Rotel DT6000 dac issues
    According to the documentation of your third-party DAC, a Windows or macOS driver is required for USB output. This means your USB output is not asynchronous communication and not just a DAC but is simple SPDIF. You will have better performance using COAX.
    That being said, your NODE X has an ESS SABRE high-quality DAC (why it is a step up from the NODE X). Try the analogue out and let your ears decide.
  • Burjor
    The Lumin U2 mini has zero issues with the DT6000, i wonder why? I guess the Node X usb compatibility is low with Dacs compare to the Lumin streamers, anyways will try a COAX connection soon.
    Thanks.
