Sound stability
  • James Voos
    I have the same problem with ApplePlay for a few seconds on some songs.  Seems like a Appleplay connection problem.  High end disappears at the start on my NAD M10 V2, and then recovers after about 15 seconds into a song.  Sounds like this isn't just Spotify...
    HI James
    AirPlay, like Spotify Connect is an end-point solution so works very similar. Go ahead and try Seppi's suggestion to check this. If you need further assistance, The Support Crew is only a menu option away in Settings, Send Support Request form the Home page of the BluOS App.
