Bluesound Hub - Gain
BeantwortetDear,
A 'Nice to have' feature, or maybe 'necessary' feature would be to be able to set Gain-levels for the analog inputs on the Bluesound Hub.
Switching from external audio streams( or local library, Airplay, Bluetooth, .. ) to the analog streams from the Bluesound hub results in a gigantic decrease of audio volume.
The other way round; switching from Bluesound Hub instreamed audio to external streams without preemptive volume adjusting, surely is a test for the power your speakers can handle / makes sure everyone in the neighbourhood is awake ... :-|
Hi Joris
You can create a preset in the BluOS App and have the source of the Preset have a predetermined volume. Use the preset to pick the source. Here's how; https://support.bluos.net/hc/en-us/articles/360012637674
Meanwhile, I have passed your feedback along to our product development team.
Dear,
Any progress or thoughts on the 'input Gain' or 'stream level' feature request fot the Bluesound Hub ?
I would like to solve this level difference. :-|
Thanks,
Best regards,0 -
I have the same problem, using the analog mm phono input on the hub having the node on max volume and the volume on full on the amp, and still able to do conversation in the room , the gain is simply too low
Best regards
Lennart0 -
I too would like to see this, the gain on phono input is very low.
If I connect my rega phono preamp in to the analogue input of the hub it is so much louder.
I was hoping not to need to keep the rega and go direct to the hub.
4 Kommentare
