Node 2 to ANK 2.1 Dac clicking and popping
BeantwortetI have a Node 2 that has been great, however I bought a new dac and now the node is putting clicks and popping into my system without the music even playing. The dac in using is a ANK 2.1, I know it's not the dac as I have isolated to the Node. I'm using the spdif cable as that's the only input on my Ank. I have tried different cables with no change.Anyone have any suggestions aside from buying a new streamer?
Thanks Seppi,
The problem is I'm not even sending music at this point. The popping and scratching is before I play anything0 -
Did a factory reset, tried using an RCA no avail. Still scratching/popping as soon as the unit is on.
