    Hi Patrick.
    A blue blinking LED on a NODE indicates the player is muted. This is consistent with the mute command on your TV. Consult your TV documentation as to why a mute command is being sent via CEC.
  • Matt Smith
    I have this VERY similar issue with my Samsung TV.  Every time the HDMI input is auto-sensed, the input is switch to HDMI but the output (from TV to Node) is muted. The only way to get sound is to pick up the TV OEM remote and unmute it.
    I've tried a bunch of work-arounds, but nothing works. I kept getting told it's a TV problem... BUT, my last version of the Node didn't seem to exhibit this issue nor does the WiiM Ultra when I have it connected. It swaps inputs just fine with auto-detect.
  • Lars-Olov
    I have this too with a Philips TV. Unaccetable in 2025. I can't even use AirPlay when the TV signals to the amp that it is to be muted.
    So far I regret buying a Powernode.
