Broken Pipe - Audio muting
4 Kommentare
    Brian
    Lossless
    A 'broken pipe' error is a connection error (interruption) which might be on either end of the transmission stream. It *might* help to log out of Qobuz and then log back in. Otherwise log a support request through BluOS Help.
  • Frankie Howard
    I should have mentioned, the error message that came up once when the sound stopped playing was ‘broken pipe’. I’ve only seen that once on the app though.
  • Bevan wison
    Same here. I run Qobuz via Bluesound Node 130  Drop outs ( silence…no reconnection)  getting annoying now. First noticed this about two weeks ago. Previous to that ,  I have been running this streamer glitch -free for nearly two years.  Got "broken pipe" message for first time today.
  • Frankie Howard
    Tried rebooting and resetting, many times. Doesn’t work. Player is up to date. WiFi network is without issue. I haven’t had the same issues with Spotify
