Bluesound Node 2i with subwoofer
Beantwortet2 Personen folgen
Bluesound Node 2i with an external preamp DAC that connected to poweramp, Can I use the bluesound sub out?
The bluesound is in output level fix
Sub should be connected to the equipment that's controlling the volume.
When output level is fixed, the sub out will be at maximum volume. -
Thans,but the pre Amp dont have sub out...
Is your sub powered with a high level input? If that's a yes then you maybe don't need a sub out on your amp, but could go from the same outputs that go to your speakers (I know this applies to REL subs but don't know about other brands)
