Default volume
4 Kommentare
    Permanently deleted user
    You can use presets, on each preset you can define input, volume as well as playing specific music. Presets can then be triggered either using the hardware preset buttons, the BluOS app or the Bluesound RC1 remote control.
  • Carsten Thomsen
    Hi any solution for this?
    Turn on device with individual sound level?
  • Boutchous
    Hello, this is not really a solution because when the Bluesound turns on by itself once it receives the Hdmi-arc signal you cannot program a default volume on this input
  • Carsten Thomsen
    Hi
    Yes not the best solution.
    But works for me in my setup
    What i did was set the volume I want the Flex player to have when turn on the 1-5 preset buttons.
    Then in app find HOME > tap "genveje"
    (danish. which I assume is preset. What a genial translation :-)
    then tap "vis alle" (show all).
    Tap 3 dots right of any of your preset.
    Tap "rediger" (Edit)
    Turn on the setting "brug nuværende lydniveau" (use current sound level).
    tap save.
    Now will flex player allways start on this sound level, when using any of the preset buttons.
