LG C3 TV and Pulse Soundbar+ eARC problems.
Eine Person folgt
5 Kommentare
    Hi Chris
    Thank you for letting us know. Glad to hear you have a workaround but it has been sent to our QA Team for investigating. The main difference between ARC and eARC has to do with compression rate so you will not hear any audible performance changes having this set to the TV.
    Since we have not heard or seen this before, likely something LG changed recently.
  • Chris J
    Can’t be a LG problem as the same happened when the store connected a Phillips TV. And enabling eARC compatibility works when connecting my amp.
    Thanks Chris... our default is to re-test the standard first. We only narrow down on brands if we can't replicate or reproduce...
  • Chris J
    Opened a support ticket to get you to look into the matter. Will be happy to send log files if needed.
  • Michel Tetteroo
    Hi, any updates on this issue. I have the same setup and am experiencing exactly the same issue: no sound via eARC on LG C3.
