Power Differences in France
4 Personen folgen
6 Kommentare
    Rays Jazz
    The UK is 240volts, despite what the EU says, it has not change. Can go upto 253v.
  • Rays Jazz
    Where are you moving from?
  • What makes you think Paris power is any different from the power in the rest of EU and UK?
    Power runs on 230V/50Hz, generally called 220V. Check your devices if they can handle both 110/220 input.
    The pictures I find for the Powernode show 110-120/220-240V-50Hz just above the power in socket, so that should be fine. Most electronic devices can handle these, but always take a look at the back before plugging in.
    Using a transformer may occasionally work, but if you are moving you should avoid using converters for your appliances. I personally do not have much trust in these.
  • Bjørn Ulvik
    It is safe.
    No adapter needed, just use the 220V AC cord included in the box.
  • Randy Dolan
    Thanks everyone. We live in Denver, CO.
  • Guy Saddy
    @ Randy Dolan I hope you love it, Paris is a great city. Best of luck with the move.
