Constant Flashing Ethernet Port
    Neuromancer
    Hate to inform you about this but that's just what the thing does haha. It annoyed me as well so I just put a tiny piece of black tape over it. Completely absorbs the light.
    I remember searching the web about this myself back then. I found a post right here in the Bluesound forum. Some employee answered that they cannot control the little LED haha.
  • Rays Jazz
    Yes that is what it does. You can try covering it over with black tape or similar. When not in use you can unplug the cable, if it really bothers you or switch it off.
  • Andrew
    🤣🤣🤣 How annoying! Now the big job of finding the masking tape in the shed…! Thanks all 👍🏻
