PulseFlex 2i - Temperature
Beantwortet2 Personen folgen
I have a pair of PulseFlex 2i speakers wall mounted in an unheated sunroom where, in the winter, temperatures may dip to 20 degrees F. What temperature range is safe to leave the speakers mounted without having to take them inside?
Thanks!
Even though we're Canadian and a -7C (20F) isn't bad for a February Day, I wouldn't recommend having them in there for prolonged amounts of time. I would equally be concerned if they get too hot. I have a similar spot in my own home.
I would stick to the typical consumer electronics general rule of thumb of between 10C and 32C (50F and 90F on the old scale).
Thank you for the quick reply!
2
