Update 4.2 created problem with stereo, only sound on left side.
BeantwortetHi,
Equipment: i-node 2,
Since the new update this week to 4.2, my sound don’t allow stereo anymore fut left only. I tried oviiyslly to change via settings (left,right,stereo…) but there’s no change.
Restarted, reseted… not solved. Until last week and 4.02 version, was working perfect (same connections too). Only after the firmware got updated, 1 minute after the stereo problem occurred.
Any possible fix? Can I downgrade to 4.02 and try update again?
Note: app is also updated latest version.
Any suggestion?
Thanks for your help!
Sergi.
Hi Sergi
Can you please select Settings, Send Support Request from the Home Page (Help, Send Support Request if you are on Windows or a Mac). This will send our Support Crew a log file of your NODE 2i so we can have a better idea of what is happening here. Once they have those and review them, they will reach out via e-mail.
Thank you Tony,
Just made.. sent via the app (Send support request). I'll wait to get contacted.
Thnaks for your help!
Sergi.
Hi,
Problem solved! Disconnected all connectors, reseted, and connected back. Problem solved and Stereo working again. All good! :)
Thank you.
