Node "Connecting to Network" Green Flashing Light
2 Personen folgen
    Hi Thomas
    This is not an uncommon occurrence and is not related to 4.x's update. This usually is caused by your router dropping the NODE connection, usually due to confusion on the router's network table. Reboot your router, wait 5 minutes then reboot your player and other network devices to clear your router's cache.
    If the problem persists or returns, e-mail us at support@bluesound.com
