After update to BluOS 4.0.2 Node 130 not visible in Tidal Connect
BeantwortetAfter update of Node 130 to BluOS 4.0.2, the player is not shown in the Tidal Connect list. Reboot of player and router did not fix the issue.
Hi Joe
If after a router reset as you suggested did not solve the issue, please send our Support Crew a log file by selecting Settings, Send Support Request in the BluOS App.
Tony, thank you for the reply. After a further restart it is working fine now.
