the fives best sound possible
4 Kommentare
  • Kristofer Hadodo
    Lossless
    Hi Munsoor,
    here's what you should look for: https://nadelectronics.com/product/nad-cs1-endpoint-network-streamer/
    It handles Deezer HiFi via Chromecast and can connect to your Fives by optical cable, or analog (if prefering the NAD DAC).
    Best, KriHad
  • munsoor saad
    i meant KLIPSCH THE FIVES POWERED SPEAKERS i wanna connect them to BLUESOUND NODE  network streamer
  • munsoor saad
    thank you KriHad, could the RCA be an option or is Optical best in this situation?
  • Kristofer Hadodo
    Lossless
    Yes Munsoor, it's either/or, depending on what sound you prefer. With optical you will hear the signature Klipsch sound. With RCA you are getting the NAD sound treatment.
