Node X solid red light, now shutting down
4 Kommentare
    HI Tilvantil
    Remove the power conditioner. Plug it straight into street power.
    If the problems persist or return, please select Settings, Send Support Request in the BluOS App so our Support Crew may take a closer look.
  • David Levine
    Did this ever get resolved and if so, what was the fix? I sold my 2i recently to upgrade to the x and have experienced the same issues out of the box.
  • David Levine
    So USB out only works on certain devices? That sucks, pardon my glibness. I’ve used a cellphone with a usb adapter and it played just fine through the Prima. Unsure why that wouldn’t natively be possible for my current setup. As far as tidal, it’s not lag it’s about the node not showing as a connect device
  • David Levine
    I spoke with Prima Luna and they stated that all streamers are compatible. The blurb in the manual is specifically for a computer input scenario but that is a one off. Their team stated to get with the streamer team to work out the issue because all inputs on the Prima are designed compatible out of the box with the exception of a few computer systems which need a driver
