Problem QOBUZ playlists in 4.0,2,
BeantwortetI Cannot add any songs to playlist in Qobuz since 4.0.2 update on WINDOWS. The message shows up the adding is done (see pic) But the playlist is not altered! Please fix this bug. Works FINE IN 4 ON iPHONE. tHANKS
HI Koridon
We are having a hard time replicating this. Please uninstall and reinstall a fresh download of the BluOS App from www.bluesound.com/downloads
If the problem persists, please select Help, Send Support Request in the BluOS App for Windows so our Support Crew may take a closer look.
Just to be sure, the Qobuz playlist is NOT changed although the feedback is given that the song is added. Please give it a try to find out.
