Import library in repaired Vault
Hallo all,
how long das it takes to restore a Vault library from a usb HD?
the restore is running now for 16 hours and the App says 26 more hours to go.
Is this normal?
I must say that I have a big library and on the old vault there was 25% of free space.
Thank you.
Max.
This sound fairly normal, the Vault still has to be a player as well as able to rip new CDs so the restore and backup functions are a lower priority.
Thank you Seppi,
the restore lasted about 45 hours but looks OK.
I have about 35% free space left on my Vault, is this save or should I delete albums to
get more free space on the Vault for it to work without hickups?
thank you for all the answering you do on this forum!
Max.
Hi Max, the space on the Vault is absolutely fine.
