Bluesound RC1 battery drain problem
9 Kommentare
    Permanently deleted user
    I found that the majority of batteries available including Duracell ones were fake. I ordered some directly from an electrical supplier in the UK and making sure I did not touch the battery with my bare hands when inserting them they last about six months.
    Genuine Duracell batteries are is a tamper safe package and have a bitrex label that needs peeling off before use. If yours did not have this then I would be suspect of their origin.
    If you still have issues please contact support by using the BluOS App.
  • Antonio B.
    Okay, will give that a try!
    I wasn't careful when touching them, and I was using generic (IKEA) batteries as well, so one of those might be the issue.
    Thanks
  • Antonio B.
    I'm bumping this after trying what you suggested - I still have the same problem.
    I bought a new set of Duracell CR2032 batteries, and carefully inserted them without touching them with my fingers and the remote is dead after 3 days and almost no use.
    What are my options now? Thanks.
  • Philippe Angst
    Same here. Using new Duracell CR2032 batteries and after a couple days the remote is dead and requires new batteries.
  • Vincent Hazelaar
    I've got the same issue, battery drain in just some days. Somebody a sollution?
  • Dechamps gilles
    Hello,
    I also have the same problem, new Duracell batteries, installed correctly, discharged in a few days without use.. what to do?
  • Vincent Hazelaar
    I bought an aftermarket remote. EUR 20 no draining batteries anymore.
  • Joscha
    Same here.
    Bought the remote 5 days ago and it’s already empty.
  • Rob Mcalister
    i have the same problem. replaced original batteries that had stopped working with newly purchased duracell batteries and remote stopped working again after around a week. replaced again from different pack of purchased batteries and same result.
