USB hd won`t disconnect.
BeantwortetAfter unplugging the USB drive it still showes connected. Library will not go away and I`m constantly being asked to share USB even though it`s not connected. Android and windows11. Only fix is to rebuild index in diagnostics.
Hi Mike
In the BluOS App, select Settings, Music Library and disable Server Mode. Once completed, restart your player. If you have a VAULT, please then Rebuild the Index from Settings, Diagnostics.
Here is a Help Centre Article with more details; https://support.bluos.net/hc/en-us/articles/360037137354
Server mode was never enabled.checked and still disabled. Node N130
Please select Settings, Send Support Request so our Support Crew can review your log file and troubleshoot further.
