BlueOS 4.0 a few problems
6 Kommentare
    Thanks Rico
    Our Quality Assurance Team has been able to replicate this.
    Look for an update in the early part of next week to address this and some other minor issues. We just want to spend the weekend testing some of these fixes.
    Thanks for your patience and understanding.
  • Lucky
    I’ve also found some bugs and posted them in a topic, but I don’t know if you read old topics. So hereby a crosspost:
    Found 2:
    -TV does not show Dolby or quality in de app
    -Spotify does not show quality, but if I first play an Apple lossless file from usb and then switch to Spotify the Bluesound app tells me I’m listening to Apple lossless via Spotify.
  • Alain DW
    Lossless
    Another thing I noticed using 4.0: when clicking on the dots asking technical info about a track, the text doesn't show as long as you don't move the cursor (laptop/ windows 4.0) to the cross to shut down the pop up.
    Clicking on the cross doesn't close the frame until you move the cursor away from the cross.
    Not dramatic but needs some getting used at and not very elegant.
  • Boudewijn
    Thanks Seppi. I found that when I switched to ethernet from wifi the data transfer was sufficiently higher which improved functionality immediately. Maybe I'd been too impatient or maybe the software didn't tolerate the slow wifi!
    All seems as it should at the moment. Problem solved.
    "I love deadlines. I like the whooshing sound they make as they fly by".
    I love me some Douglas Adams - This Moderator's all-time favourite Author...
  • Alain DW
    Lossless
    Yes, he is good isn't he. If only the answer to the issues on hand was 42.
