Bad sound quality
Hello, i own node 3, yamaha as701 and dali oberon 7. When i use rca pre out sound is too bright, almost it is not audible when i open up volume and it is very annoying. When i use optical out it sounds very nice with yamahas dac. Is there any chance my node is faulty?
I use cd input and fixed output. I will change it now to line 1. Could this make a difference?
Direct cd sounds definitely better than pure direct with node. But still optical+pure direct is the best combination.i changed to line 1 and i dont see things getting any better..
Maybe it is just that. I thought that a "better" dac should sound better. But maybe it is not always this way.. Thank you for your time!
Well i made several tests and i can say for sure that the problem was the cd input, i just needed some time to get used to it. I changed to line 1 input and everythink is fine as it should be. Now i like node's dac better. Thank you!
4 Kommentare
