Powernode Edge vs. Soundbar+ connection with LG-QNED TV
4 Kommentare
    Hi Michael
    Your problems are likely Wi-Fi related and will not be resolved by using a POWERNODE EDGE. The EDGE does not support being a front channel product in Home Theatre Grouping. Please select Help, Send Support Request in the BluOS App for assistance from our Support Crew.
  • Michael
    Uuups....
    my Wi-Fi is like a rocket :-) That can't be the problem! Never ever. Sure!
    To classify the topic better again.
    I HAD the Soundbar+. But sent it back because it did not work as expected. Unlike Sonos (which worked fine). But I initially did not want to switch to Sonos, because I already have BlueSound components. But maybe I have to then to do (?)
    Uuups....
    We have seen that and can help. Please go ahead and send the Support Request. What do you have to lose
  • Michael
    Thanks!
    Hmmm, I don't think we understand each other. I would like to know BEFORE buying if something has been improved in the "Problematic". For example, because the technology (eARC - TV connection etc.) in the PN Edge is better than that in the Soundbar+. If that is not so, then it will again not work satisfactorily for me. Because then they could have helped me with the Soundbar+ ;-)
