Using a Powernode 2i as rear channel on home theater setup
2 Personen folgen
    Mark T.
    Sr. Support Crew Member
    Hi Jordi,
    Thank you for your feedback. There is no need to swap speaker cables. The BluOS software will automatically switch (internally) the left to the right and vice-versa when configured in a Home Theater setup as rear speakers. And when you would like to break the group and only use the POWERNODE, it will go back to its normal settings where left is left and right is right. Please let me know if this answered your question.
    Thanks for #LivingHiFi
  • Jordi Vilanova
    Thanks! Yes everything is super clear now.
