loudness control ?
    Hi Erika
    In your audio settings of your Player, enable Tone Controls and add some additional bass. Here's how; https://support.bluos.net/hc/en-us/articles/360000303168
  • Erika Voskamp
    I know these settings.
    But it is much to little for me.
    I am used for instance to a Denon receiver, and if you push loudness on that one, it is more then those tone controls :-) on low volume.
    Then it sounds bigger and more dynamic.
    Other wise I have such a flat sound.
    But thank you for your message !
  • Erika Voskamp
    Just try it your self.
    Take a unit with loudness control and one without it.
    Turn the volume not to loud and listen to it.
    And without a sub I mean.
    Then you will hear the difference.
    It is much much more dynamic.
    But again thank you for quick reply !
